Topic "(ESshFatal) Network error: Connection timed out"
mlovejoy
Confused
We are currently expericign a problem that maybe someone can help me with.
I have two compaines who are trying to connect to our server using WinSCP and they are getting netowrk errors.
I can connect fine from home and using another SFTP client so I do not think it is our server.
. WinSCP Version 3.3.0 (Build 177)
. Login time: Friday, September 17, 2004 3:07:45 PM
. Session name: LTI@x.x.x.x
. Host name: x.x.x.x (Port: 22)
. User name: LTI (Password: No, Key file: No)
. Transfer Protocol: SFTP
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Looking up host "x.x.x.x"
. Connecting to x.x.x.x port 22
. Attempt to close connection due to fatal exception:
* Network error: Connection timed out
. Closing connection.
* (ESshFatal) Network error: Connection timed out
Any help or advice would be appreciated.
Michelle Lovejoy
mlovejoy wrote:
Confused
Michelle Lovejoy
I want to make a pun sooo bad.. Razz
