Topic "Automating Download from SFTP remote site"
falcrawl
All
New to this but achieving some measure of success.
I am connecting to a sFTP site to download a bunch of files everyday to a new folder created everyday by the date stamp. (Done this with a batch file and schedule it to run everyday)
My script is as follows
option batch abort
open sftp://user:password@site.com -hostkey="ssh-rsa 1024 34:2b:a4:06:c7:40:ea:6c:1e:ae:b7:c2:82:34:db:ef"
get -delete -resume -filemask="/Outbox/*.pdf" "Z:\sub1\sub2\MMDDYYYY\
Question.
How can I get the script to verify the correct folder and download the files to that folder for that day. The next day a new folder is created and the files for that day will be downloaded to the current folder
Not sure what you mean by "verify the correct folder".
But to download files to the folder named after the current day use:
get -delete -resume -filemask="/Outbox/*.pdf" "Z:\sub1\sub2\%TIMESTAMP#mmddyyyy%\
See http://winscp.net/eng/docs/scripting#timestamp
falcrawl
Thanks but this did not work.
Well, would your mind giving us more details? Describing what "does not work"? A log file? Anything?
