Topic "Renaming local files"
janiop
I am new to WinSCP and in my script I put a file to a remote directory but I want to rename the local version by adding YYMMDD in the file name. How can I accomplish this?
Newbie
Do you mean you want to upload the file using its original name and after the upload archive the original local file by appending the timestamp to its name?
janiop
Exactly.
There's a very similar example available:
http://winscp.net/eng/docs/script_local_move_after_successful_upload
janiop
thanks but it doesn't tell me how to add the timestamp.
Well, that's not a task for WinSCP.
Simple google search will give you a solution.
See for example http://stackoverflow.com/q/17996936/850848
