Topic "Privatekey not accessible via Task scheduler"
legionnl
Goodday,
i have a batch file with a script in it using WINSCP 5.7.5.
the upload script is quite basic:
open sftp://username@servername:2222 -privatekey=Privatekey.ppk -passphrase=@password
lcd E:\Projectdata\projectname\Export\Processed\
put *.txt
if i activate the batch file with the serviceaccount used by task scheduler there is no problem.
howeever if i activate it via taskscheduler i get the following error in the log file
. 2015-10-08 14:01:20.669 Reading private key file "Privatekey.ppk"
. 2015-10-08 14:01:20.669 Unable to use this key file (unable to open file)
! 2015-10-08 14:01:20.669 Unable to use key file "Privatekey.ppk" (unable to open file)
! 2015-10-08 14:01:20.669 Using username "username".
. 2015-10-08 14:01:20.810 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2015-10-08 14:01:30.841 Disconnected: Unable to authenticate
Any help would be appreciated,
Legionnl
I assume the startup directory of the batch file is different to the directory the private key file is contained in. Use a full path to the private key.
legionnl
unfortunately no. all files are in the same folder. Batch file, scriptfile,scriptlog and Privatekey.
however it was the solution to this problem thank you very much.
That does not contradict my claim that the startup directory of the script is different.
