Topic "GetFiles Method Has Started Attempting to Delete Remote Directory"
tmiddleton
We started getting permission denied exceptions out of nowhere the other night. It's coming from the remote server when we try to remove the remote files after downloading. We are using GetFiles method with the Remove flag set to true. There were no code changes on our end that I know of and at the time of first occurance we were running 5.7.1. I found a similar bug report and upgraded to 5.7.5 but the behavior has not changed. Is there a way to disable this behavior? I only want the files removed not the folder.
I apologize in advance if this this is already covered somewhere but I could find no other reference to this behavior nor any property I could set to turn it off.
I've attached the relevant portion of the log.
Log.txt (4.23 KB) [Download]
Description: (none)
What "this behaviour"?
Show us your code and the session log file (Session.SessionLogPath).
tmiddleton
Hello, thank you for responding so quickly!
The behavior or action I want it to take is to delete the remote files that were successfully downloaded but not the remote directory. The login being used doesn't have sufficient privileges to remove a directory so the permission denied exception is being returned and causing the script to terminate with a failure code.
I've included the script below. The log I attached in the fist post is from the session log file. I'll get you a more complete version if needed asap.
$CurrentDir = Split-Path ((Get-Variable MyInvocation -Scope 0).Value).MyCommand.Path
$ProcessingFolder = "\\local\path\"
try
    Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = ""
    $sessionOptions.UserName = ""
    $sessionOptions.Password =
    $sessionOptions.SshHostKeyFingerprint = ""
    $sessionOptions.Timeout = New-TimeSpan -Seconds 30
    $session.SessionLogPath = "$CurrentDir\WinSCP.log"
    $transferOptions.TransferMode = [WinSCP.TransferMode]::Automatic
    $transferOptions.FilePermissions = $null
    $transferOptions.PreserveTimestamp = $False
    $transferResult = $session.GetFiles("/remote/path/", $ProcessingFolder, $True, $transferOptions)
    $transferResult.Check()
catch [Exception]
    ...Send Email...
    exit 1
finally
    # Disconnect, clean up
    $session.Dispose()
tmiddleton
Attaching Session log file...
Log (2).txt (11.71 KB) Private file
Description: (none)
So download (and delete) the files only, not the parent directory:
$transferResult = $session.GetFiles("/remote/path/*", $ProcessingFolder, $True, $transferOptions)
