Topic "is-6B9S7.exe"
Grendel
you should add the info that after an install of the latest build a new file (is-6B9S7.exe) is placed in the system folder. When I rebooted, suddenly that strange-unknown-obscure potentially virulent exe file wanted to start up with my system, so I blocked it. A .lst file below says
* List of files to be registered on the next reboot. DO NOT EDIT! *
[s]D:\Programme\WinSCP3\DragExt.dll
so... what is it actually for? Smile
Btw, google couldnt find it which is something that never happened to me before when I wanted to know something Wink
ciao
Grendel
DragExt.dll is WinSCP drag&drop shell extension. You can see it, if you show file priperties in Explorer.
You need not to install it, there is a check for this in installer.
You may learn more at the end of this topic.
