Topic "recent file edit"
jsbsmd
It would be nice if you had a drop down under the files tab that would list the last 10 or so files you had edited for a particular session and remember them when you go into winscp later.
An example of this would be when transversing linux directories needing to edit in the /etc /var /usr/local directories when working on certain issues.
regards,
John
Good idea. Thanks for your suggestion.
