(ESshFatal) Server unexpectedly closed network connection
Nealia
I am able to connect to WinScp just fine when I am not at home. I have used Winscp all semester and it just stop working. Please see the script I receive:
l. 2015-10-20 19:05:55.496 --------------------------------------------------------------------------
. 2015-10-20 19:05:55.496 WinSCP Version 3.7.6 (Build 306) (OS 6.1.7601 Service Pack 1)
. 2015-10-20 19:05:55.496 Login time: Tuesday, October 20, 2015 7:05:55 PM
. 2015-10-20 19:05:55.496 Session name: gq034@cs2.uco.edu
. 2015-10-20 19:05:55.496 Host name: cs2.uco.edu (Port: 22)
. 2015-10-20 19:05:55.496 User name: gq034 (Password: Yes, Key file: No)
. 2015-10-20 19:05:55.496 Transfer Protocol: SFTP (SCP)
. 2015-10-20 19:05:55.497 SSH protocol version: 2; Compression: No
. 2015-10-20 19:05:55.498 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2015-10-20 19:05:55.498 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2015-10-20 19:05:55.498 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2015-10-20 19:05:55.498 SSH Bugs: -,-,-,-,-,-,-,-
. 2015-10-20 19:05:55.498 SFTP Bugs: -,-,-
. 2015-10-20 19:05:55.498 Proxy: none
. 2015-10-20 19:05:55.498 Return code variable: Autodetect; Lookup user groups: Yes
. 2015-10-20 19:05:55.498 Shell: default, EOL: 0
. 2015-10-20 19:05:55.498 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2015-10-20 19:05:55.499 Cache directory changes: Yes, Permanent: Yes
. 2015-10-20 19:05:55.499 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2015-10-20 19:05:55.499 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2015-10-20 19:05:55.499 --------------------------------------------------------------------------
. 2015-10-20 19:05:55.500 Looking up host "cs2.uco.edu"
. 2015-10-20 19:05:55.509 Connecting to 204.154.117.80 port 22
. 2015-10-20 19:06:00.620 Server unexpectedly closed network connection
* 2015-10-20 19:06:00.624 (ESshFatal) Server unexpectedly closed network connection
I have tried to follow the forum discussion on this error message but I am new to this and unable to follow. Please help.
Re: (ESshFatal) Server unexpectedly closed network connection
You should contact your server administrator first.
Also you urgently need to upgrade WinSCP.
