Topic "Command Line interpretation"
JKrause
open sftp://user:password@example.com
this sample is used all over the place...
And I have tried searching
But WHAT does it mean ???
The individual parts, I mean ...
My best wild guess
sftp:// - use SFTP
user - the user ID
: - separate user ID and PW
password - your password
@example.com - the FTP site - more realistically - secureftp.mycompany.com ?, and the @ just means, well, AT ?
Your interpretation is correct.
See http://winscp.net/eng/docs/session_url
The example.com is a standard hostname reserved for examples.
See RFC 6761:
https://tools.ietf.org/html/rfc6761#section-6.5
One cannot use mycompany.com as that belongs to someone.
JKrause
Well, yes, that was my "example" rather than my real company name
And thank you for confirming my interpretation of the command line.
John
JKrause
SIGH
OK, I got a secure connection, by my PUT seems to fail.
Simple 2k text file
SCP seems to see it as 1K, ok for that...
Then sends 0.0KB/s Sad
And the file does not arrive
Standalone client (Filezilla) with the same credentials seems to work
Alt-Tab
Is there a way to Register as a user in these forums? I don't see a "Register" link.
JKrause
OK
Success
Even though the login credentials Logg me in to the destination folder required, adding the slash-folder
/destfolder/
apparently was required, anyway.
I have successfully transferred data from a command line using a script file.
Thank you
