Topic "Double Click -> Command"
Double-Click use operation to perform to select what should WinSCP do when you double-click file in file panel:
Open - open file.
Copy - transfer file (upload or download).
Edit (default) - edit file.
Please, can you add COMMAND in the list like:
Open - open file.
Command *new
Example: Double-click -> echo "winner: " >> !
With this option the user can use explorer interface with very power usability.
Thanks for your suggestion.
Will see if more people ask for this.
Btw, Do you know that you can assign a keyboard shortcut to the custom command?
