Topic "Unable to set password for the sftp site"
rahul.kolhe22
I am trying to create a bat file that can invoke WinSCP to download and upload the file on SFTP site.
Below is my code
SFTP_Code.txt
option batch abort
option transfer binary
open sftp://USER:Pass1234@example.com -privatekey=C:\temp\SFTP\Auth.ppk
get /home/SVC_CNOVA/in/test.txt
Batch file code: Auto_Batch.bat
winscp /script=C:\temp\SFTP\SFTP_Code.txt
When I try to execute the batch file from the command prompt it prompts me to enter the password. I enter the same password I gave in the open command marked in bold above.
Can you please suggest me something.
Thank you.
I assume (as you are using a private key), that the Pass1234 is not a password, but a passphrase.
The passphrase is specified using -passphrase switch:
open sftp://USER@example.com -privatekey=C:\temp\SFTP\Auth.ppk -passphrase="Pass1234"
See http://winscp.net/eng/docs/scriptcommand_open
Thanks a lot!!! it worked for me.
Kind Regards. Very Happy
