Topic "Property Window"
Adem
Could you make the property information in the Property window (of files and folders etc) as read-only but user selectable text. (see MS Windows property windows for a file to for a better explanation of what i mean).
This would be most useful to save us from typing a lot of stuff.
BTW, you might also, let the file/folder name in property window user-changeable text so that renames can also be made there.
Cheers,
Adem
Maybe. However if you want to copy file path to clipboard use File(s)/File names/Copy to clipboard
It is not the same thing. That way, all I am getting is the path.
I also need the filename. Currently, I know of no way of doing it thru WinSCP.
Cheers,
Adem
OK. Found it now.
But, if you dont mind me saying this, I find it unintuitive to go 3 menu levels to do such a thing.
One must keep the menus rather short, otherwise it becomes chaotic.
