Topic "Transfer files without extensions in ASCII mode using Automatic transfer mode"
I can't find it possible to transfer files without extensions in ASCII mode using automatic transfer mode. Is it possible to include such a feature in next release - or is there a way to do this in the latest release?
I have a lot of unix files which have no file extensions. I.e. a dir command could give this list:
~/misc$ ls
With automatic transfer mode, I want the unix script "bgtest" and the text file "bgtestdata.txt" to be transfered as ASCII; and the file redbox.gif to be transfered as binary.
Regards, Mrten Berglund, Sweden.
I do not understand why it does not with with "*.", but you are right, it does not. I'll try to fix it in the next release.
Thanks! And good luck fixing it to the next release. I look forward to that! Smile
/Mrten.
Mrten
Hello!
I've just downloaded the latest version of WinSCP (3.8.2 build 330) and looked forward to see this feature working, but it still doesn't... Sad Maybe you forgot it? I tried to use the include mask, but it didn't work either. A possible solution would be to allow regular expressions to be used as patterns in the mask feature. Then something like [^\.]* would fit.
Anyhow, thank's for all good work! / Mrten
It will be solved in 4.0.1. Coming soon Smile
Mrten
Mm, great! Look forward to seeing it. Fantastic work you're doing. Smile
Since the next release mask *. will select files without an extension (even without a dost).
Mrten
Sorry for late reply... Embarassed After two years, I've finally upgraded my WinSCP and have installed the latest version now (4.1.9). With *. transferring files without extensions automatically in ASCII mode now works just great! Thanks! Very Happy
/Mrten
Neeraj Singh
I am using below command in the script to get the files without extension from linux server:
get -filemask="*>1d" *.
but it is not working.
My current winscp version is 5.1.4
Kindly suggest if any alternative way to do it.
What is "not working"?
Please start a new topic and attach a full log file showing the problem (using the latest version of WinSCP).
