Topic "Delete directory operations"
Adem
How does WinSCP handle directory deletion?
It seems it is deleting every single item under a directory one by one.
Shouldn't it issue just a
rm -d -f -r <directory_name>
to the server. It is much much faster that way.
What protocol do you use, SCP or SFTP?
You may read something about the protocols, which may answer your question.
Adem
Thank you for the link. I was using SFTP, but having read the document at the link, I think I will use SCP (and, for the rare cases SFTP, maybe).
Just one more question, does SCP have any problems with SSH2?
Cheers
Adem
You may use SFTP, and add new custom command "rm -d -f -r !" instead.
If you mean security problem, then not. On some newer (SSH2) servers, SCP is no longer avilable, but it is rare.
