Topic "Excluded Files Mask"
n/a
Files should not be excluded if:
1) The user explicitly clicks on a single file to transfer.
2) it is to be edited. At least put up a notice telling me that the file wasn't transfered because of the mask - it currently just errors with the temporary file not found.
This is questionable. What if you select two files? Smile
I agree with this. I'll make WinSCP ignore exclude mask for editing.
Anton P.
Moreover, I mainly use exclude masks to exclude files which are typically very large, in order to prevent me from absent-mindedly transferring an enormous file to a remote filestore where I have a low space quota. To me it makes no difference whether it's one file or lots of files.
