Topic "cannot copy files from a drag operation - can only move"
stgmike
Since nobody else is reporting this, I think this must be due to something I am doing wrong, but I cannot figure it out! I can't find a configuration combination that will allow me to copy again (from a dragging operation).
I am using 3.7.1 (build 257) of WinSCP and When I drag a remote file to my desktop (or to any folder on my local computer) I am prompted to Move the file or Cancel. I used to be offered the opportunity to Copy the file (leave it on the remote server and copy it to my local computer).
I am using the Explorer interface (but I was before, too). Here is a snippet from my log.
. WinSCP Version 3.7.1 (Build 257) (OS 5.0.2195 Service Pack 4)
. Login time: Tuesday, December 14, 2004 4:21:48 PM
. Session name: CPHosting
. Host name: seattletech.com (Port: 22)
. User name: seattlet (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "seattletech.com"
. Connecting to 216.67.254.38 port 22
. Server version: SSH-1.99-OpenSSH_3.1p1
. We believe remote version has SSH2 RSA padding bug
. We claim version: SSH-2.0-WinSCP-release-3.7.1
. Host key fingerprint is: <edited out>
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username <edited out>.
. Keyboard-interactive authentication refused
. Session password prompt (<edited out>'s password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 49, Number: 528
. Real path is '/home/seattlet'
. Listing directory "/home/seattlet".
> Type: SSH_FXP_OPENDIR, Size: 23, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 6689, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
. Reading symlink "www".
> Type: SSH_FXP_READLINK, Size: 27, Number: 1555
> Type: SSH_FXP_STAT, Size: 27, Number: 1809
< Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< Type: SSH_FXP_NAME, Size: 43, Number: 1555
< Type: SSH_FXP_ATTRS, Size: 37, Number: 1809
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
< Type: SSH_FXP_STATUS, Size: 24, Number: 2052
< Status/error code: 0
. Startup conversation with host finished.
. Cached directory change via "public_html" to "/home/seattlet/public_html".
. Listing directory "/home/seattlet/public_html".
> Type: SSH_FXP_OPENDIR, Size: 35, Number: 2315
< Type: SSH_FXP_HANDLE, Size: 13, Number: 2315
> Type: SSH_FXP_READDIR, Size: 13, Number: 2572
< Type: SSH_FXP_NAME, Size: 8301, Number: 2572
> Type: SSH_FXP_READDIR, Size: 13, Number: 2828
. Reading symlink "bugbase".
> Type: SSH_FXP_READLINK, Size: 43, Number: 3091
> Type: SSH_FXP_STAT, Size: 43, Number: 3345
< Type: SSH_FXP_STATUS, Size: 28, Number: 2828
< Type: SSH_FXP_NAME, Size: 41, Number: 3091
< Type: SSH_FXP_ATTRS, Size: 37, Number: 3345
. Reading symlink "webcal".
> Type: SSH_FXP_READLINK, Size: 42, Number: 3603
> Type: SSH_FXP_STAT, Size: 42, Number: 3857
< Type: SSH_FXP_NAME, Size: 63, Number: 3603
< Type: SSH_FXP_ATTRS, Size: 37, Number: 3857
. Reading symlink "webreg".
> Type: SSH_FXP_READLINK, Size: 42, Number: 4115
> Type: SSH_FXP_STAT, Size: 42, Number: 4369
< Type: SSH_FXP_NAME, Size: 47, Number: 4115
< Type: SSH_FXP_ATTRS, Size: 37, Number: 4369
> Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
< Type: SSH_FXP_STATUS, Size: 24, Number: 4612
. Cached directory change via "pdf" to "/home/seattlet/public_html/pdf".
. Listing directory "/home/seattlet/public_html/pdf".
> Type: SSH_FXP_OPENDIR, Size: 39, Number: 4875
< Type: SSH_FXP_HANDLE, Size: 13, Number: 4875
> Type: SSH_FXP_READDIR, Size: 13, Number: 5132
< Type: SSH_FXP_NAME, Size: 1253, Number: 5132
> Type: SSH_FXP_READDIR, Size: 13, Number: 5388
< Type: SSH_FXP_STATUS, Size: 28, Number: 5388
> Type: SSH_FXP_CLOSE, Size: 13, Number: 5636
< Type: SSH_FXP_STATUS, Size: 24, Number: 5636
This F.A.Q. may help you. There are several topics on the forum that explain the problem in more details.
stgmike
Thanks for pointing this out. Excellent product, excellent support!
- Mike
