Error Code 127
sdwhittaker
Error Code 127
I suddenly developed a problem with WinSCP in that i can no longer transfer files. I get a message
"Copying files from remote side failed" and
"Command failed with return code 127."
Where can i find an index to error codes?
Re: Error Code 127
It is server-side error code. You won't find any index here. But usually it means that scp binary cannot be found on the server. You may try SFTP instead of SCP.
