Topic "File of 27G size shows up as -2G and won't transfer"
The remote server has a number of 27G files I need to sync with local storage. They show up as -2G when I view the remote directory and when I try to transfer them they error out. All other files transfer fine. Suggestions?
Thanks. Smile
What protocol, SCP or SFTP? If SFTP, what version?
Version of WinSCP is 3.7.1 Build 257. Syncing was done with SFTP.
Are you saying you think the problem might be at the server end? Regular FTP reports file sizes accurately if that helps.
Thanks. Smile
John,
Maybe. I'm not aware of any problems WinSCP may have listing files over 2GB. I've forgot to ask what is the plaform of the server and what SSH server are you using.
