Topic "Different default file permissions depending on location"
Anton P.
I mainly use WinSCP for two purposes: backing up work, and uploading webpages. In my case the remote fileserver is the same, and I have two main directories:
/blah/blah/<my-username/mydocs
/blah/blah/<my-username/public_html
When I transfer files to some subdirectory of mydocs, I want the default permissions to be -rw------- with "Add X to directories".
When I transfer files to some subdirectory of public_html, I need the default permissions to be -rw-r--r-- with "Add X to directories".
[Incidentally, thanks for making "Add X to directories" use the common-sense approach of only adding an X for user-groups which are given R.]
I'd love it if I could tell WinSCP that when I'm transferring into a subdirectory of public_html, it should use one set of default permissions, and that in all other cases it should use another.
I understand that, in theory, there is no logical limit to the complexity of this; you could have a "profile" for any directory you wanted. But, to begin with, it seems reasonable that there should at least be a way of informing WinSCP of a web directory which may well require different default permissions than other directories.
I receive regularly requests to make some defaults specific to somethink else, be it session, server, directory or file. It would together make up rather complex system. I do not mean I'll never implement it, but it is not high priority for me.
