Topic "can't install winscp"
hi there,
unfortunately I have troubles installing winscp 3.7.2.
I am using WindowsXP Service Pack 2...
After doubleclicking the .exe, I get the message:
"16-Bit-MS-DOS-Teilsystem
Die NTVDM-CPU hat einen ungltigen Befehl entdeckt."
(It's a german sys, : )
Can anybody help?
thx a lot
bernhard
vienna, austria
Download the installer again. It should have about 1,5 MB. Note that the download link points to mirror-selection page, so you cannot right click it and select "save target as" or similar.
Thanks a lot, that hint solved the problem.
I tried it with right-clicking before... Embarassed
Regards,
Bernhard
