Topic "INI file"
Hi, For some reasons I don't see winscp3.ini file in my default directory. Is there a how to document to create a .ini file for winscp?
Thank you.
There is a document Smile
Thanks for the quick response. I actually am aware of that document. I was looking more of documentation of what I should put inside the .ini file itself.
Something like
defaultdirectory=c:\xyz,
I am looking for all possible variables.
Thank you..
Why do you want to make it that difficult to yourself? Smile
Just edit your preferences on login dialog. Then you can investigate the INI file to see what and how it sets.
