Topic "assertion in 3.7.2-3.7.4 connecting thru SOCKS 5"
Marc
This works fine in 3.7.1 but fails in later versions:
http://marc.abramowitz.info/images/WinSCP%20bug%20screenshot.JPG
Here is the config, which I suspect is causing it (because other more "normal" [non-proxied] connections work fine):
http://marc.abramowitz.info/images/WinSCP%20proxy%20settings.JPG
localhost:1080 is PuTTY port forwardind to a remote SOCKS proxy.
Let me know if you need any other info to debug this. I'd be glad to help. Email me at msabramo@yahoo.com
Thanks for report, I'll check it and eventually contact you.
Triwill
I get the same assertion error as Marc and use socks5
Was able to get 7.1 to work.
Jerry2005
Hi everybody,
I have the same problem with 127.0.0.1 and socks4.
By the way: I searched a lot but have not been able to find a bugtracker or bug-forum for this message, 'til I finally found this topic.
Probably considering some time to do a "buf-forum"?
Thanks in advance,
sincerely
Tom Wiegand
I have made attempt to fix this. Unfortunately I do not have any SOCK proxy to debug it myself.
That's what the support forum is for.
1) I do not think it is up to the end user to decide if
something is bug or not. You post it here. I decide if it is bug or your misunderstanding Smile If course in this case, it is quite obvious, but it is seldom so.
2) Most people does not care where do they post their messages. So if they do not differentiate between "support" forum and "feature requests" forum, adding third forum wouldn't change anything.
OK, I already know that I have not fixed it. I also know by sure that the problem is in PuTTY code, so I'll ask them for help.
I believe that workaround would be to check Consider proxying local host connections on Proxy tab.
mava70
No probme with 3.4.2 trought my socks5 proxy, 3.7.4 doesn't work. Looking for 3.7.1 to see it it works
M
mava70
I can confirm tha 3.7.1 works for me
Marco
I would rather like to know if 3.7.4 works for you when Consider proxying local host connections is checked. Thanks in advance.
Marc
I am able to connect with that setting checked in 3.7.4
-Marc
Thanks for letting me know.
bernhard
i had the same problems as mentioned above. checking "Consider proxying local host connections" works!
Thanks!
