Topic "Setting for default sync direction"
I wish to use WinSCP to sync from server to local. Unfortunately the direction of the synchronise dialog box defaults to which ever side of the interface is active at the time.
Would it be possible to add an option to override this to set the default sync direction on a per session basis and for it to ignore if the local or remote directory side of the window is active.
OK, I'll consider it.
