Topic "Mouse Bug"
duerra
This is just a small note, but when attempting to press the X-Left or X-Right mouse buttons to navigate back/forward directories, an error dialog pops up when you've reached the beginning or end - "List index out of bounds". This popup could simply be removed without worry (I assume it was in place for testing purposes).
Also, on a somewhat related note - if you have two connections to the same server in the same WinSCP instance, and you try and navigate with the X-buttons when going back and forth between the different sessions, the last/next directory histories gets intertwined with eachother.
Thanks for your incredible dedication to such a fantastic product Smile
duerra wrote:
When you put everything into something, it means everything to you.
Thanks for letting me know. I'll fix it.
Yes, the directory history is shared between the sessions (not only between sessions on the same host). It is known drawback. I'll fix it Smile
