Topic "Error watching for changes in directory"
daftbusker
First, I'd like to thank you for the software, it's great. I'm using 3.7.4
I'm trying to use the 'Keep remote directory up to date' and it's chokes on one sub-directory. The error is
Error watching for changes in directory 'M:\home\daft\project\project-files\admin\user-scripts\'
M: is a samba share on a Linux server, winscp is on windows 2000.
I went in and recursively chmoded and chowned the whole directory in case it was a permission problem but to no avail. I also did a lsattr but I didn't see anything. There are sub directories in the user-scripts directory, but I have done other transfers with a larger number subdirectories (5 I think)
What was particularly strange was that if I go into the admin folder (in the above example) and then run the command, I don't get an error... My work around is to open several instances of winSCP but it's kind of clumsy.
Thanks for any help.
I have improved error reporting for this case. Please download updated version and try again with it. Then post the full error message (do not forget to press "More" button or copy full error message using Ctrl+C). Thanks.
daftbusker
Thanks for the help.
It now says the problem is with a directory inside the directory reported in the previous error.
(If you compare the new error message to the one in my last post, you'll see the directory names are slightly different because I'd typed (not c&p'ed) the old error, but I was pretty close.)
The new error:
Error
Error watching for changes in directory 'M:\home\daft\project\project-dev\root\user_scripts\root_tables'.
OK
I double-checked the permissions, etc., but I still don't see anything funny.
Are you sure you have used the version linked from my post? You should have "more' button on the message to show additional info. Like:
Error
Error watching for changes in directory 'D:\XXX'.
System Error. Code: 2.
Cannot find the path specified.
OK
I'm leaving for one week now, so please do not expect another reply soon.
daftbusker
OK that makes sense, the error is:
System Error. Code: 56.
The network BIOS command limit has been reached
This article:
http://support.microsoft.com/default.aspx?scid=KB;en-us;q271148
Mentions using the latest Service Pack for w2000 but I have 4 installed... I'm gonna check the Samba settings.
Have you found anything?
daftbusker
No, nothing yet. I spent a few hours looking around and couldn't turn up anything. I don't have the time to poke around too much right now, but if I figure out a solution I'll post it here. Opening a few winscp's at once won't kill me.
Thanks again for the software and your help,
- Daft
FodderMK
I get the error as well:
The directory it has problems with isn't always necessarily the same. I do seem to notice a correlation between this error and the number of files/directories though. If I tell WinSCP to monitor a relatively empty directory then everything works fine. If I tell it to monitor a directory with many files and subdirectories then I get this error.
I'm using WinSCP 3.7.5 (Build 294) on a fully-patched WinXP system. The settings I have checked in the "Keep remote directory up to date" window are "Update subdirectories", "Existing files only" and "No confirmations". If I uncheck "Update subdirectories" then WinSCP also works correctly, reinforcing the "trouble with lots of directories" theory.
If you'd like me to run any more tests just let me know. I don't have any control over the remote box, however, so the testing I can do there is limited.
It seems that there is some system limit on number of directories being watched. If this is true, I can hardly do anything about that. BTW, is the directory you are watching on network drive?
What is approximate number of subdirectories in the directory?
FodderMK
Yes, actually, it was on a network drive. So for testing I mirrored everything relevant on the network to my local machine and tried it again. The error did not occur. So it seems like the solution (for me) is to work on my local machine.
To answer your other question, there are 406 folders, 1540 files. Another project I work on contains 802 folders, 4925 files. For that project I get the following error when attempting to use the "Keep remote directory up to date" feature:
"Cannot watch for changes in more then 500 directories and subdirectories"
But at least that error code makes sense to me and I'll be able to work around it. Thanks for your help!
BTW, 500 is limit imposed by WinSCP.
Jens P.
i am on Win2k and files are stored at a novell network directory!
the webserver is a linux machine
Error watching for changes in directory 'R:\Data\_CurrentProject\abwesenheit_test':
System Error. Code: 1.
Unzulssige Funktion
I think Unzulssige Funktion in English is illegal or forbidden?!
what can be the reasons?
greetz
p.s.
if i try to use a local directory the automatic syns procedure starts and waits fpr changes but changes are not recognized!? what are the reasons?
Jens P.
Jens P. wrote:
p.s.
sorry for that on a local folder it works! i was my fault..
but can you explain the error on the novell network directory?
Your Novell network probably does not support the "change notification" functionality.
tjfulopp
Ahoj Martin,
The "Keep remote directory up to date" does not work if the source is on Novell server. This has been a serious problem for me since there are several people who need access to the source files. In this forum, I see other WinSCP users need it as well.
Do you have plans to introduce this functionality in the coming release of WinSCP? I understand Novell may work differently than Windows but I can imagine there are ways to achieve it.
Thanks for the amazing software -
Tom
If the novell drive does not support the notification, I cannot do anything about it. Perhaps it is configurable?
Vacilando
I can formulate a question for a Novell discussion forum or their support people. What should I ask them about -- what signal / process / flag is it, technically speaking, that WinSCP needs to know in order to register a change in a directory?
Travel in All Senses
http://www.vacilando.org
Pada
I'm getting exactly the same error as Jens P.:
Incorrect function
I know its the same error, because I've worked in Germany for a few months and I've been to Prague Smile
Anyways, I have tried WinSCP 3.8.2, 4.1.8 & 4.2.3 beta and they all give the same error. I'm trying to "Keep remote directory up to date", where my local direcotry is a SAMBA share on Ubuntu. I'm actually running Windows XP as the guest OS & Ubuntu as the host OS using VirtualBox.
Using Debug 2 level, it is showing:
. 2009-10-22 22:43:22.830 Session upkeep
. 2009-10-22 22:43:22.830 Looking for network events
. 2009-10-22 22:43:22.830 Timeout waiting for network events
. 2009-10-22 22:43:23.311 Session upkeep
. 2009-10-22 22:43:23.311 Looking for network events
. 2009-10-22 22:43:23.311 Timeout waiting for network events
. 2009-10-22 22:43:23.812 Session upkeep
. 2009-10-22 22:43:23.812 Looking for network events
. 2009-10-22 22:43:23.812 Timeout waiting for network events
. 2009-10-22 22:43:24.453 Session upkeep
. 2009-10-22 22:43:24.453 Looking for network events
. 2009-10-22 22:43:24.453 Timeout waiting for network events
. 2009-10-22 22:43:24.813 Session upkeep
. 2009-10-22 22:43:24.813 Looking for network events
. 2009-10-22 22:43:24.813 Timeout waiting for network events
I guess its impossible to fix WinSCP since it's an underlaying error of Windows / SAMBA shares?
Regards
Chris Kistner
Incorrect function
I've sent you a debug version, did you get it?
Pada
Yes, I did receive the email. I was just too busy with my project at the time.
I've ran the debugging version, replicated the error and uploaded the log file to: http://www.mediafire.com/file/4t0ijwkkmqe/WinSCP0B74trace.log
Pada
OK, I've ran the winscp424pada build. With that build it managed to get further than the other stable/development builds. It even showed "Watching for changes in 92 directories...", which it weren't able to do previously. HOWEVER, it's immediately crashing right after it showed that in the status listbox.
The trace log file has been uploaded here: http://www.mediafire.com/?5mmwnwzd1zm
Sorry for delay. In the log I can see that WinSCP was running yet minutes after that. So do you say that the WinSCP window disapeared from your desktop?
Pada
No problem.
I find that strange that the Window was open a few minutes after that. It might be that I've left the error message open to try and copy the Windows crash report.
I've now rerun the same debugging application again and this time I quickly closed the error window.
New trace log (zipped): http://www.mediafire.com/file/zwmuzj42222/WinSCP0BE8trace.zip
If you want me to run certain debugging/tracing applications I would be more than glad to do that. I'm not a reverse engineer, but I'm a quite capable Java/C# programmer.
Thanks for all your time & effort that you've put into this problem.
Regards
Chris
OK, anyway, I haven't found anything I can change in WinSCP to make it working for you. I'm Sorry.
Pada
OK, thanks for the reply.
I think I'll resort to 2 WinSCP instances. One for watching the changes on my computer, which then copies the files to the local WinXP machine, and then another WinSCP instance for watching & updating the remote server.
