Topic "continue copying files in script after error"
vitty
i have a problem. i need backup files on servers to major server and then backup on tape. i write this script:
option batch on
open user@IP
option transfer binary
get /home c:\zaloha\IP\DATE
close
I need continue copying files when is error with any file.
eroor log:
c:\Internet\SSH\ZALOHA>zaloha
batch        on
confirm      off
Inicializace...
Hledn hostitele...
Spojovn s hostitelem...
Autentikace...
Using username "user".
Autentikovno.
Přprava...
Čten vzdlenho adresře...
Připraveno.
Aktivn spojen: [1] user@IP
transfer     binary
home                      |          0 kB |    0,0 kB/s | binary |   0%
debian                    |          0 kB |  651,0 kB/s | binary |   0%
Koprovn souborů ze vzdlenho adresře selhalo.
Obecn selhn (server by měl poskytnout popis přčiny chyby).
Kd chyby: 4
Chybov hlen zaslan serverem: Failure
Kd poadavku: 5
Spojen 'user@IP' uzavřeno.
dn otevřen spojen.
or
javakey.1.gz              |          0 kB |  361,0 kB/s | binary |   0%
Nepodařilo se otevřt vzdlen soubor '/etc/alternatives/javakey.1.gz'.
Soubor nebo adresř neexistuje.
Kd chyby: 2
Chybov hlen zaslan serverem: No such file
Kd poadavku: 3
Pře(r)uit, (O)pakovat, (P)řeskočit: Přeruit
dn otevřen spojen.
thanx for answer and sorry for my english Twisted Evil vitty
Pripojuji jeste dotaz v cestine pro snadnejsi pochopeni meho problemu. Kopiruji data ze serveru na hlavni server (z Linuxu na WinXP). Pri prubehu kopirovani se mi prikaz get ukonci s vyse uvedenyma chybama. Potreboval bych, aby skript tyto chyby preskocil a pokracoval dal v kopirovani. Tento skript mi pobezi v noci a sam. Po ukonceni se spusti zalohovani na pasku.
There's currently no way how to ignore the errors and continue. You need to avoid copying files that cannot be copied.
it's impossible check files before copying. i need daily back-up ahead given folders on few servers and i don't know what is in this folders. when some file is just now in use or in linux one folders reffering on another folder, i don't know, how this file or folder before copying detect and eliminate from copying.
is any idea?
thanx for answer, vitty
Have you tried other command-line SFTP client, like PSFTP?
psftp copy only files. i find program tunnelier by bitvise and then work without errors.
