Topic "Fonts too large in file panels!"
Hello Martin,
First - many thanks for the excellent program!
I am having a problem with font size in the latest WinSCP release 3.7.4 build 271.
The font in the file panels is apparently much larger than the icon font in Windows (XP).
I did not have this problem with the 3.3.0 (177) release.
My resolution is 1280x1024, with 150% fonts.
The icon font is Tahoma 9.
Thanks a lot!
Thanks for info. I'll check it.
I just installed the same build (271) and the font size in the file panels
(Norton mode) is HUGE.
I have a 1400x1050 display with font size set at 125%.
WinXP pro Build 2600.xpsp_sp2_rtm.040803-2158(SP2)
1600x1200 - Appearance options: Windows Classic Style, Normal Font size, no advanced appearance options.
WinSCP 3.7.4 Build 271
On split upper/lower panel, only the lower panel has larger font.
P.S. Thanks for a great utility!
Dittos on the mega font size here as well.
Dell Inspiron laptop, W2K SP4 with current MS patch set. nVidia GeForce2Go on a 1600x1200 screen w/font size == 150%
Many thanks for the most excellent program, it's great stuff!
Allen Woolley
Las Vegas, NV
As an example, look at the screen grab at :
My setup Windows XP SP2; screen resolution 1920x1200 pixels, 32bit depth.
WinSCP 3.7.4
