Topic "Compiling WinSCP"
sanjiv
First of all, WinSCP is awesome!
I know I need Borland C++ to compile. However, is there a free compiler out there that I can use? I don't have BCC.
Thanks.
I don't know if there is free BC++ compiler. But anyway you would need also BC++ libraries, which are probably not free.
Could you generate a optimized version (I think BCC generate pentium pro optimized code if you include a -6 at compiler switches)?
I can try it to see if there will be any significant benefit.
Thanks.
I am also a user of WinSCP since version 2.
And I am really appreciate your work.
I saw free version of BCC5.5 and TD at borland site.
But no VCL library.
I also would like to know which version of C++Builder6.
They have C++Builder6 Pro and Personal(also Enterprise)
and "personal" is cheaper than "Pro" Smile
Any C++ Builder 6 version will do, including Personal Smile
hosaka
Thank you for your reply!
If I make significant change onto your code, I will send sources to you. I am suspicious about wchar handling at filename lists (especialy if they contain Japanese char.)
Tnanks again for your corporations.
Fine, I'll appreciate that.
