Topic "Batch Problem"
Is there any way of setting "option batch on" & "option confirm off" other than using /script, such as thought the .ini file?
I am running the application as a script but I do not wish to save the password in the script file so I call the following command:
winscp.exe /console /script=file.txt
It works fine but if I get the key exchange screen i.e. "The servers host key is not found...." the application will stall there waiting for user input, i.e. the script file does not execute the batch on & confirm off commands until a session has fully started.
Any ideas?
You can open the session using "open" command instead of from command line after you issue the "option batch off". But this won't help you anyway as the host key confirmation cannot be supressed for security reasons. You need to confirm the key manually first before using the script files. This problem is already discussed in topic Scripting and Authenticating.
