Topic "WINSCP called by Tasks scheduler in Windows"
Alain Her
Hi all,
I need to execute on a daily base a lot of file transfert from a server to a local machine. So i create first a session to connect the server and i saved it as a stored session.
My second operation was to include this in a ".BAT" file in order to start it in batch mode, i made a script file to pass the instruction to the WINSCP module, until now it works fine when started manually in dos prompt windows Very Happy .
Unfortunatly, when using the Windows task scheduler to manage the startup of the ".BAT", the called session failed Sad when trying to connect the server (message in the log : Host does not exist).
Why is this possible? The .BAT and the script files are fine.
Is it any issue using WINSCP within the task scheduler? Question
Thank you for attention.
Alain
I have added an answer to F.A.Q.. Let me know if it helps you.
Alain Her
Quote:
Very Happy I used another account and it works fine now.
I still need to investigate a little bit in order to use .INI file in place of registry entries. Thanks for your help.
Alain
