Topic "WinSCP not reading remote directory"
plehrer
I am trying to connect to a unix server and WinSCP is not reading the remote directory.
I keep on getting this error message:
Error listing directory "/userspace/u/p/pl".
Unexpected directory listing line "drwx--x--x 4 pl 4096 Feb 17 20:55 .".
Operation aborted
Is WinSCP using a "dir" command instead of an "ls" command? If so, how do I fix this.
Thank you,
Peter
Please read Requirements. WinSCP needs group name in directory listing. You may also search this forum, this have been asked many times already.
ljlin
I have the same problem. I just set environ. varable "LANG C",and it work well now.hope this will be helpful. Smile [/quote]
yan
I have the same problem and couldn't find an answer in the forum. I'm attaching a log file.... where is the environment variable where I can set "LANG C" ?
Thanks, and here is the log(ip addresses are changed):
. WinSCP Version 3.6.1 (Build 221) (OS 5.1.2600)
. Login time: June 16, 2004 7:27:14 PM
. Session name: asp
. Host name: 222.88.99.22 (Port: 1113)
. User name: root (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "222.88.99.22"
. Connecting to 222.88.99.22 port 1113
. Server version: SSH-1.99-OpenSSH_2.9p2
. We believe remote version has SSH2 RSA padding bug
. We claim version: SSH-2.0-WinSCP-release-3.6.1
. Host key fingerprint is:
. ssh-rsa 1024 9c:40:d0:d3:c2:3f:da:1d:77:63:78:ad:90:9c:9c:5a
! Using username "root".
. Keyboard-interactive authentication refused
. Session password prompt (root@222.88.99.22's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `echo': not an alias
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `pwd': not an alias
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `cd': not an alias
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `groups': not an alias
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `scp': not an alias
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `mkdir': not an alias
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `chmod': not an alias
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `chgrp': not an alias
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `chown': not an alias
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `unset': not an alias
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `unalias': not an alias
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `alias': not an alias
> unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `ln': not an alias
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `%s': not an alias
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. Looking up groups and users.
> groups ; echo "WinSCP: this is end-of-file:$?"
< root bin daemon sys adm disk wheel
. Following groups found:
. root
. bin
. daemon
. sys
. adm
. disk
. wheel
. No users found.
> pwd ; echo "WinSCP: this is end-of-file:$?"
< /root
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$?"
. Waiting for data timed out, asking user what to do.
. Asking user:
. Host hasn't answered for 15 seconds.
. Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. Attempt to close connection due to fatal exception:
* Terminated by user.
. Closing connection.
* (ESshFatal) Error listing directory '/root'.
. Login time: June 16, 2004 7:44:12 PM
. Session name: asp
. Transfer Protocol: SFTP
. Proxy: none
. Sent password
. Access granted
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 31, Number: 528
. Real path is '/root'
. Listing directory "/root".
> Type: SSH_FXP_OPENDIR, Size: 14, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
. Asking user:
I do not see "the same problem" in your logs. Your server does not reply. Or it takes it too long to reply. Does it help if you press "Retry" button? Maybe many times?
yan
No. it does not help. I have tried multiple retries.
Maybe I should mention that I'm using:
- Windows XP
- VPN connection to the server
- Putty works fine by itself.
Thanks.
I'm sorry but I have no idea what is the problem. However as you have the problems with both protocols, I do not this that the problem is on WinSCP-side. Have you tried other SCP/SFTP client?
yan
yes. I downloaded the evaluation verion of WinSSH and it didn't work either.
I think that the porblem is that the corp firewall does not allow VPN traffic on some ports and this affects the remote directory reading because in both clients I could SSH in using only the command line.
Do you know maybe on what ports the WinScp tries to do the remote directory reading?
Thanks.
None. WinSCP works thru SSH. So if SSH terminal works over your VPN, WinSCP should work as well. It seems rather like your filesystem is not responding to your SSH deamon. But I do not understand why.
For list of reasons WinSCP cannot parse directory listing and possible resolutions, see documentation.
