Topic "Copying Files To Remote Side Failed"
vkachoria
I have searched through the Forum messages and see a couple similar to the problem I'm encountering but they are unanswered or slightly different issues.
I hope you can help resolve this issue.
Using WinSCP v3.7.4 Build 271 on a Windows XP Pro computer to connect to a dedicated Unix/Fedora server. Currently using SFTP (allow SCP fallback) protocol, compression enabled, SSH 2.
I am able to use WinSCP to connect to the server, browse and create directories and edit files. I can even copy small files to & from the server/local system.
But when I try to upload a large number of files or sometimes a large file, I get one of two error messages:
1. Copying files to remote side failed: Server sent disconnect - message type 2 (ssh_disconnect_protocol_error): "Corrupted MAC on input"
2. Network error: software caused connection abort
I have tried changing to SCP only, with/without compressions, SSH 1, SSH 2, and have turned auto/on/off the SSH2 HMAC bug. In addition, I have tried transfer in background/foreground. None of these seem to have helped.
What would cause this and what would you suggest?
I do have a log file that I can e-mail.
Vik Kachoria
http://www.RealAdventures.com
Great Accommodations, Adventures & Vacations
Life's An Adventure - Live It!
What is your SSH server (including version)?
vkachoria
I'm very new to Unix, so I'm not sure that I am doing this correctly. I believe the SSH version is: "SSH-1.99-OpenSSH_3.6.1p2"
I got this by entering telnet server_ip 22 in a DOS command window.
I do know that the server has "OpenSSH Secure Shell" and TelNet available.
Let me know if there is a better way to get the version number for you.
Vik
I have search the internet and it suggests that it is probably hardware/network problem.
https://bugzilla.redhat.com/show_bug.cgi?id=108815
https://bugzilla.mindrot.org/show_bug.cgi?id=845
hickins
I am having the same problem here, and that happened when I forwarded the port 22 from DMZ to a network computer. Now I started to think it's a MAC address security check. I'm working on this problem. Please update if you have done anything and I'll do the same. ( ammartahan@yahoo.com )
Ammar
Vik Kachoria
