Topic "How to use customer command ?"
Gill
Hi, everyone:
I have a problem.
What's customer command and how to use ?
I wanna put some files to remote server,
If sftp files ok, move these files to another folder in windows client.
But it can't work about customer command.
For example use !mv or !cp.
how can I do ?
It can't recognize about an exclamation mark.
I'm very confuse about this.
please tell me if you have any answer.
Thanks a lot of.
Gill
To learn how to use custom commands you may check the pre-defined example commands.
But if you want to automate file transfers you are probably looking for scripting feature.
Gill
Very sorry!!
I describe my question not clear !
I use winscp3.com in windows BAT file.
It can work if I use "!" command.
How can I use "!" command in winscp3.com or command line model?
Is it feasible ?
Gill
Sorry, I have typing error in here.
「It can't work if I use "!" command.」
Gill wrote:
Very sorry!!
Is it feasible ?
OK, so you want to execute server-side command from the script, do you? You cannot do this with WinSCP, yet.
