Topic "Allow edit doc to bypass filter"
duerra
Martin,
This should be a fairly simple adjustment. Since right-clicking and editing in WinSCP allows you to open a document for editing purposes (bypassing the default filters), when the document is saved, it should also be uploaded bypassing the default filters. Currently, it does not.
When mass-moving files, I don't want a configuration file to be overwritten, so it's on the default exceptions list. However, when right-clicking and selecting "edit", and opening it in EditPad Pro, the file opens fine, but does not re-upload after saving any adjustments that I've made.
Thanks Smile
duerra wrote:
When you put everything into something, it means everything to you.
OK, I've thought I've fixed this in 3.7.2
Quote:
Bug fix: When downloading file to editor, Exclude mask and operation mask were not ignored, what prevented editing some files.
But I've fixed it only for downloading, not for uploading Sad
Thanks for info.
duerra
Thanks Smile
