Topic "Problem Synchronizing Files"
Confused
Did this file make it or not? Your help would greatly be appreciated.
2005-03-25 04:30:07.125 Copying 1 files/directories to remote directory "/test/store"
. 2005-03-25 04:30:07.125 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: No; Mask: *.*
. 2005-03-25 04:30:07.125 TM: B; ClAr: No; ExclM:
. 2005-03-25 04:30:07.140 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2005-03-25 04:30:07.140 File: "c:\test\store\test.DAT"
. 2005-03-25 04:30:07.140 Copying "c:\test\store\test.DAT" to remote directory started.
. 2005-03-25 04:30:07.140 Binary transfer mode selected.
. 2005-03-25 04:30:07.140 Checking existence of file.
> 2005-03-25 04:30:07.140 Type: SSH_FXP_LSTAT, Size: 83, Number: 11015
< 2005-03-25 04:30:07.171 Type: SSH_FXP_STATUS, Size: 24, Number: 10756
. 2005-03-25 04:30:07.171 Discarding reserved response
< 2005-03-25 04:30:07.203 Type: SSH_FXP_STATUS, Size: 29, Number: 11015
< 2005-03-25 04:30:07.203 Status/error code: 2
. 2005-03-25 04:30:07.203 Checking existence of partially transfered file.
> 2005-03-25 04:30:07.203 Type: SSH_FXP_LSTAT, Size: 92, Number: 11271
< 2005-03-25 04:30:07.234 Type: SSH_FXP_STATUS, Size: 29, Number: 11271
< 2005-03-25 04:30:07.234 Status/error code: 2
. 2005-03-25 04:30:07.234 Opening remote file.
> 2005-03-25 04:30:07.234 Type: SSH_FXP_OPEN, Size: 108, Number: 11523
< 2005-03-25 04:30:07.265 Type: SSH_FXP_HANDLE, Size: 13, Number: 11523
> 2005-03-25 04:30:07.265 Type: SSH_FXP_WRITE, Size: 4121, Number: 12038
. 2005-03-25 04:30:09.156 23 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2005-03-25 04:30:09.156 Type: SSH_FXP_CLOSE, Size: 13, Number: 15364
< 2005-03-25 04:30:09.156 Type: SSH_FXP_STATUS, Size: 24, Number: 14854
< 2005-03-25 04:30:09.187 Type: SSH_FXP_STATUS, Size: 24, Number: 15110
< 2005-03-25 04:30:09.437 Type: SSH_FXP_STATUS, Size: 24, Number: 15364
< 2005-03-25 04:30:09.437 Status/error code: 0
> 2005-03-25 04:30:09.437 Type: SSH_FXP_RENAME, Size: 170, Number: 15634
< 2005-03-25 04:30:09.468 Type: SSH_FXP_STATUS, Size: 24, Number: 15634
< 2005-03-25 04:30:09.468 Status/error code: 0
> 2005-03-25 04:30:09.468 Type: SSH_FXP_SETSTAT, Size: 95, Number: 11785
< 2005-03-25 04:30:09.515 Type: SSH_FXP_STATUS, Size: 24, Number: 11785
< 2005-03-25 04:30:09.515 Status/error code: 0
. 2005-03-25 04:30:09.515 Closing connection.
Yes it did. Why do you ask?
Confused
I guess because it had the error code 2 and because it was checking for a partial file.
OK, but you must see whether the file is there or not.
To understand the check for partial file, read about transfer resume.
