Topic "far plugin: restore connection (same directory)"
vlad
would be good if "connection aborted" banner has restore connection button that would restore the connection and take you back to the same dir where it was lost.
Smile
Vlad
OK, I'll try Smile
Due to bug in FAR, I've found it impossible to implement your request without huge changes in the code. So I have postponed this.
vlad_
it's a pity, thanks for trying though.
btw, I saw there is fresh beta of FAR available, maybe the bug you are referring to is corrected in that version ?
http://farmanager.com/
Vlad
Thanks for letting me know. I'll try it. Unfortunatelly they do not provide list of changes.
Also I can hardly rely on people having "alpha" version. Even now I'm blamed to make the plugin required "beta" version Smile
Shurman
Still, this is the most uncomfortable thing for now (though the latest plugin version is _significantly_ better than previous ones!!) - basically, I can not leave a big file (10-20 Mb) copying and go away - since the banner stops the process. Sad
The regular FTP plugin automatically restores the connection - is it not affected by the bug?
This is something duifferent that what this topics discus. We only discussed possibility to "reconnect" lost connection. What you want is much more complicated and neither the WinSCP application does not support this. I'll eventually try to solve this, but it will take time.
I haven't written that it is not possible at all. I've just meant that with the plugin as is, it will be quite difficult to hack it to override the FAR's bug.
t-rex
What is that bug in FAR you are talking about, could you please report it here or in the official FAR forum http://forum.farmanager.com/viewforum.php?f=26
I do not remember exactly the problem. Generally it was that FAR ignores some calls to service functions when called from certain exported functions.
I believe in this case it was Control(FCTL_UPDATEPANEL) or Control(FCTL_CLOSEPLUGIN) called from ProcessEvent(FE_IDLE).
Could you please report such problems in the future, cause if you don't report we have no way of fixing it.
I've reported some errors in past, without ever getting any response.
t-rex
The question is to where you were reporting the problems. If it was to support@farmanager.com then it probably was lost cause that address haven't been working for years, because of large amount of spam. The best place to report the problems nowdays is in the new offial forum. And for problems with API it is best that you provide a simple test plugin with sources.
