Topic "Windows shell delay"
I have WinSCP version 3.7.1 on Windows 2000. I will try to describe you some odd behaviour of windows shell (Explorer) when I transfer file on "foreground". If, during the transfer, I double click a file in Windows Explorer, the program bound to the file is not started immediately, several seconds Windows does nothing (the new process is not started, I checked with Program Manager), then the program is launched (with empty document), again several second of wait and after then the file is opened and I can work. This odd behaviour is not present when I transfer on background or no tranfer at all. I am sure that this is caused by WinSCP, it somehow blocks Explorer.
Can you replicate this behaviour?
Thanks, Jan
I'll check it.
This is not problem of WinSCP, something strange with my Win2k.
Jan
