Topic "Invoke remote script"
max
I have a script (etudata1) residing on my mainframe system. I want to ssh to the mainframe and invoke this script. Is there a way to achieve this using the command line
Following are the commands that I am using
winscp> open 172.27.192.81
User name: nussdet1
Initialisation...
Searching for host...
Connecting to host...
Authenticating...
Using username "nussdet1".
'nussdet1@172.27.192.81' session password:
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] nussdet1@172.27.192.81
winscp> cd /web/webdept/nusss/dev
winscp> ./etudata1 TSSET03 LIST NVASHOME
Unknown command './etudata1'.
Max
Next version will allow this. But anyway SFTP/SCP client is not the proper tool for this kind of task. Consider using plink from Putty package.
max
I have already tried plink . Doesnt work ...
I am trying to call plink / putty from a dll. Both dont get invoked at all , when I call them using ShellExecute .
Here's the code that Im using
wsprintf( param, "-ssh -load \"%s\" -l \"%s\" -pw \"%s\" -m \"%s-ssh.txt\"" , appbase , sshusr, sshpass, appbase );
wsprintf(log , "Parameter -> %s \n" , param );
PK_log ( log );
ShellExecute( NULL , "open", "putty.exe", param, "" , SW_HIDE);
My dll calls cmd.exe but doesnt call putty.exe or plink .exe Question . I had hence rested hopes on winscp. Do you know of any other tools which do this ?
And most important ...When are you planning the next version release ?
Max
Hmm, that's strange. And with WinSCP it works?
Send me an mail and I'll send you link to new version straight away.
max
Just in case you didnt get the mail
vsmartybrain@yahoo.com
Max
max
Works like magic now.. Razz
Max
