Topic "Logging"
max
Is there any method of logging the output of the command to a file. I am able to run a remote command using call, but in some cases I need the output of the command.
Is there a way to log this into a file.. or any other means of logging?
Max
max
Hi ,
Sorry, have now found the logging option. Works great in GUI mode & console mode ..But ..alas doesnt log any output when run in scripting mode
I am invoking winscp using the following command
winscp /console /script=cmd.txt
The file cmd.txt looks like this
option batch on
open user:pass@172.27.192.81
cd /web/webdept/nusss/dev
call ./etudata1 TSSET03 SET NVASHOME GBNUANV5
close
I have turned logging on for the above session. Unfortunately it doesnt log any output. Am I missing something ..?
Also .. is there any way of getting the output of the command call
in a file
i.e output of "call ./etudata1 TSSET03 SET NVASHOME GBNUANV5" in a file
Max
It works even in scripting mode. Please check again.
Probably you are, but I do not know what Smile
Quote:
Also .. is there any way of getting the output of the command call in a file
No.
