Topic ""Invalid Memory Access" - WinSCP (v3.74 French translation)"
WolFoeniX
Hi all !
I found a bug in WinSCP 3.74.
I just put WinSCP 3.74 on a fresh install of Windows XP SP2 on my laptop.
I choosed to install this soft in French.
Everything works except that if every time I launch the program, it says (in French) "Invalid Memory Access". More over, you can't save any application preferences like explorer selection style, external editor, panels state...
After some investigations, I decided to replace the files WinSCP.fr by a fresh downloaded version from this website. No way, same problem.
So I removed this files : Now my WinSCP is in English (it's ok for me) and I don't have any memory error nor problem with preferences saving.
I don't know if it's only the French translation that causes this bug. I don't have time to check the other languages.
Now waiting for version 3.75 of WinSCP Razz
Best regards
WFX
Unfortunatelly I'm not able to reproduce this.
Why? Any error or it just does not save?
WFX
No error message, just don't save any application preferences.
WFX
And this was also solved when you have removed french translation?
WFX
Yes ! I think maybe the message doesn't appears when you close the software.
Can you check if anything at all is stored in WinSCP configuration?
