Topic "Permission Settings"
The Outsider
I am trying to setup WinSCP through a corporate system. Currently the system manages to make a connection only if the user has full administrative rights to the PC. I have set the temp directory to be a directory called C:\Temp which all users have access to. But I still get an error stating "Directory D: does not exist" (the D:\ is the CDROM of the PC). If I then add the user into the Administrators group of the local PC they connect fine.
Any help would be much appreciated.
Thanks!!
TheOutsider
3.4.2 (Build 197)
Thanks!!
I believe that this was fixed in 3.6.5. 9 months ago!
