Topic "installers or and program could have version number included in the name"
matteo
hi thanks for the great program!
it might be less confusing to have the version number as part of the filename on your betas. that way you don't end up with different versions all named the same.
also off topic. i think that some sort of cache from files transferred by the program remained on my system after the program ended. i was using a beta several months old, however...
thanks again,
matteo
If you notice this problem with latest version, please tell me.
