Topic "su to root as suggested in FAQ does not work"
vzagvozdin
I was trying to setup a WinSCP session to su to root account after logging to a server.
I read FAQ, followed instructions, but it did not work for me.
First, on the server I validated that I can "sudo su" without being prompted for a password.
Then in WinSCP-Environment-SCP-Shell I selected option "Enter", and typed "/usr/bin/sudo su".
WinSCP connects, then dispays message "Starting session", and then aborts.
Did I configure smth wrong?
The box is Linux Red Hat 7.2.
WinSCP is version 3.7.1
Can you post a log file?
Also can you try this using PuTTY? Specify your command "/usr/bin/sudo su" in "Remote command" box on Connection/SSH tab.
Salix
I would like to join this thread, because i've got the same problem. I tested the sudo su login with putty -> it works fine!
But wscp won't do it ...
Can you help me?
THANKS
Salix
Log:
. 2006-01-04 18:41:47.046 --------------------------------------------------------------------------
. 2006-01-04 18:41:47.046 WinSCP Version 3.7.6 (Build 306) (OS 5.2.3790 Service Pack 1)
. 2006-01-04 18:41:47.046 Login time: Mittwoch, 4. Januar 2006 18:41:47
. 2006-01-04 18:41:47.046 Session name: steffen@domain.tld
. 2006-01-04 18:41:47.046 Host name: domain.tld (Port: 22)
. 2006-01-04 18:41:47.046 User name: steffen (Password: No, Key file: No)
. 2006-01-04 18:41:47.046 Transfer Protocol: SCP
. 2006-01-04 18:41:47.046 SSH protocol version: 2; Compression: No
. 2006-01-04 18:41:47.046 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-01-04 18:41:47.046 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-01-04 18:41:47.046 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-01-04 18:41:47.046 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-01-04 18:41:47.046 SFTP Bugs: -,-,-
. 2006-01-04 18:41:47.046 Proxy: none
. 2006-01-04 18:41:47.046 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-01-04 18:41:47.046 Shell: /usr/bin/sudo su -, EOL: 0
. 2006-01-04 18:41:47.046 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-01-04 18:41:47.046 Cache directory changes: Yes, Permanent: Yes
. 2006-01-04 18:41:47.046 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-01-04 18:41:47.046 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-01-04 18:41:47.062 Looking up host "domain.tld"
. 2006-01-04 18:41:47.250 Connecting to 81.XXX.XXX.XXX port 22
. 2006-01-04 18:41:47.359 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:47.359 Looking for incoming data
. 2006-01-04 18:41:47.421 Select result is 1
. 2006-01-04 18:41:47.421 Server version: SSH-2.0-OpenSSH_3.7.1p2
. 2006-01-04 18:41:47.421 We claim version: SSH-2.0-WinSCP_release_3.7.6
. 2006-01-04 18:41:47.421 Using SSH protocol version 2
. 2006-01-04 18:41:47.421 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:47.421 Looking for incoming data
. 2006-01-04 18:41:47.468 Select result is 1
. 2006-01-04 18:41:47.468 Doing Diffie-Hellman group exchange
. 2006-01-04 18:41:47.468 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:47.468 Looking for incoming data
. 2006-01-04 18:41:47.687 Select result is 1
. 2006-01-04 18:41:47.687 Doing Diffie-Hellman key exchange
. 2006-01-04 18:41:48.046 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:48.046 Looking for incoming data
. 2006-01-04 18:41:48.218 Select result is 1
. 2006-01-04 18:41:48.609 Host key fingerprint is:
. 2006-01-04 18:41:48.609 ssh-rsa 1024 b7:0a:5c:8c:4d:ec:72:3f:bb:7c:xx:xx:xx:xx:xx:xx
. 2006-01-04 18:41:48.640 Initialised AES-256 client->server encryption
. 2006-01-04 18:41:48.640 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-01-04 18:41:48.640 Initialised AES-256 server->client encryption
. 2006-01-04 18:41:48.640 Initialised HMAC-SHA1 server->client MAC algorithm
. 2006-01-04 18:41:48.640 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:48.640 Looking for incoming data
. 2006-01-04 18:41:48.796 Select result is 1
! 2006-01-04 18:41:48.796 Using username "steffen".
. 2006-01-04 18:41:48.796 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:48.796 Looking for incoming data
. 2006-01-04 18:41:49.000 Select result is 1
. 2006-01-04 18:41:49.000 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:49.000 Looking for incoming data
. 2006-01-04 18:41:49.062 Select result is 1
! 2006-01-04 18:41:49.062 Using keyboard-interactive authentication.
. 2006-01-04 18:41:49.062 Password: prompt from server
. 2006-01-04 18:41:49.062 Asking user for response.
. 2006-01-04 18:41:53.578 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:53.593 Looking for incoming data
. 2006-01-04 18:41:53.703 Select result is 1
. 2006-01-04 18:41:53.703 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:53.703 Looking for incoming data
. 2006-01-04 18:41:53.796 Select result is 1
. 2006-01-04 18:41:53.796 Access granted
. 2006-01-04 18:41:53.796 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:53.796 Looking for incoming data
. 2006-01-04 18:41:53.906 Select result is 1
. 2006-01-04 18:41:53.906 Opened channel for session
. 2006-01-04 18:41:53.921 Waiting for the server to continue with the initialisation
. 2006-01-04 18:41:53.921 Looking for incoming data
. 2006-01-04 18:41:54.015 Select result is 1
. 2006-01-04 18:41:54.015 Started a shell/command
. 2006-01-04 18:41:54.015 --------------------------------------------------------------------------
. 2006-01-04 18:41:54.015 Using SCP protocol.
. 2006-01-04 18:41:54.015 Doing startup conversation with host.
. 2006-01-04 18:41:54.015 Skipping host startup message (if any).
. 2006-01-04 18:41:54.015 Sent 36 bytes
. 2006-01-04 18:41:54.015 There are 0 bytes remaining in the send buffer
. 2006-01-04 18:41:54.015 Sent 1 bytes
> 2006-01-04 18:41:54.015 echo "WinSCP: this is end-of-file:0"
. 2006-01-04 18:41:54.015 Waiting for another 1 bytes
. 2006-01-04 18:41:54.015 Looking for incoming data
. 2006-01-04 18:41:54.109 Select result is 1
. 2006-01-04 18:41:54.109 Waiting for another 1 bytes
. 2006-01-04 18:41:54.109 Looking for incoming data
. 2006-01-04 18:41:57.109 Select result is 1
. 2006-01-04 18:41:57.109 Server sent command exit status 1
! 2006-01-04 18:41:57.109 Password: su: incorrect password
. 2006-01-04 18:41:57.109 Waiting for another 1 bytes
. 2006-01-04 18:41:57.109 Looking for incoming data
. 2006-01-04 18:41:57.359 Select result is 1
. 2006-01-04 18:41:57.359 All channels closed. Disconnecting
. 2006-01-04 18:41:57.359 Server closed network connection
. 2006-01-04 18:41:57.359 Waiting for another 1 bytes
. 2006-01-04 18:41:57.359 Looking for incoming data
* 2006-01-04 18:41:57.375 (ESshFatal) Fehler beim berspringen der Startnachricht. Ihre Kommandozeile (Shell) ist mglicherweise nicht mit dieser Anwendung kompatibel (BASH wird empfohlen).
* 2006-01-04 18:41:57.375 Die Verbindung wurde unerwartet geschlossen. Der Server sendete den Befehlsbeendigungsstatus 1.
You need to make sure that 'su' won't ask for password.
Salix
I'm sure! With putty it's working!
Sorry, I have no clue then. In the log I can see "Password: su: incorrect password"
pluggo
My guess would be that you're doing 'sudo su' in putty, and just plain 'su' in winscp. To allow su'ing without a password (on a PAM-based system), edit /etc/pam.d/su and add this line:
auth sufficient /lib/security/pam_wheel.so use_uid trust
Then, as long as you're in the group 'wheel', you should be all good.
-b
