Topic "Deleting a file from the remote server"
Graham Cracker
How do I delete a file from the remote server after I have successfully downloaded it?
I use the following script file:
option batch on
open user:user@255.255.255.255
get dnload.txt d:\usr\local\dirname
close
I am executing this script file from the following batch file:
@echo on
cd C:\program files\winscp3
winscp3 /console /script=dnload.txt
if errorlevel 1 goto failure
if errorlevel 0 goto success
:success
echo FILES SUCCESSFULLY DOWNLOADED!
goto end
:failure
echo ERRORS DURING TRANSFER. FILES WERE NOT DOWNLOADED!
:end
Any help you can give me will be greatly appreciated.
Launch another script with WinSCP from "if errorlevel 0".
