Topic "XP Style?"
Is there any way not to use the new XP look of menus and toolbars? (Disable XP look or similar?) I have been loving WinSCP but the new look makes it much more "nervous" (the old look may be out of fashion but it was actually great).
Smile
You can use "Office 2000" theme intead, what is quite similar to original style. You need to import following registry settings:
REGEDIT4
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface]
"Theme"="Default"
PsychoMark
Thanks! Would be nice to have an option in the interface if that hasn't already been added... the whole .NET UI hype made me nervous as well Smile
This also works fine in the .INI btw when using that, which is perfect for me because I carry WinSCP on an USB disk to be able to manage my server anywhere...
Will do Smile
coth
i just had a question on theme.
afaik WinSCP uses TB2K+TBX. could be next version compiled with office2003 theme... i'm pretty like, i'm sure many other people as well:)
<invalid link removed>
I'll consider it, at least Smile
