Topic "Authentication problems"
Would you please have a look at the following log and let me know why I can't log in using Winscp. Thank you in anticipation.
. 2005-05-17 22:36:41.101 --------------------------------------------------------------------------
. 2005-05-17 22:36:41.111 WinSCP Version 3.7.4 (Build 271) (OS 5.1.2600 Service Pack 2)
. 2005-05-17 22:36:41.111 Login time: Tuesday, 17 May 2005 10:36:41 PM
. 2005-05-17 22:36:41.111 --------------------------------------------------------------------------
. 2005-05-17 22:36:41.111 Session name: uuuuu@xxx.xxxx.xx
. 2005-05-17 22:36:41.111 Host name: xxx.xxxx.xx (Port: 22)
. 2005-05-17 22:36:41.111 User name: uuuuu (Password: Yes, Key file: No)
. 2005-05-17 22:36:41.111 Transfer Protocol: SFTP (SCP)
. 2005-05-17 22:36:41.111 SSH protocol version: 2; Compression: No
. 2005-05-17 22:36:41.111 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-05-17 22:36:41.111 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-05-17 22:36:41.111 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-05-17 22:36:41.111 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-05-17 22:36:41.111 SFTP Bugs: -,-,-
. 2005-05-17 22:36:41.111 Proxy: none
. 2005-05-17 22:36:41.111 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-05-17 22:36:41.111 Shell: default, EOL: 0
. 2005-05-17 22:36:41.111 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-05-17 22:36:41.111 Cache directory changes: Yes, Permanent: Yes
. 2005-05-17 22:36:41.111 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-05-17 22:36:41.111 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-05-17 22:36:41.111 Looking up host "xxx.xxxx.xx"
. 2005-05-17 22:36:41.161 Connecting to xxx.xxx.xxx.xxx port 22
. 2005-05-17 22:36:41.291 Server version: SSH-1.99-OpenSSH_3.5p1
. 2005-05-17 22:36:41.291 We claim version: SSH-2.0-WinSCP_release_3.7.4
. 2005-05-17 22:36:41.291 Using SSH protocol version 2
. 2005-05-17 22:36:41.361 Doing Diffie-Hellman group exchange
. 2005-05-17 22:36:41.551 Doing Diffie-Hellman key exchange
. 2005-05-17 22:36:43.554 Host key fingerprint is:
. 2005-05-17 22:36:43.554 ssh-rsa 1024 27:3b:eb:bf:61:b7:35:94:31:a3:a9:b3:f0:f9:d8:e8
. 2005-05-17 22:36:43.554 Initialised AES-256 client->server encryption
. 2005-05-17 22:36:43.554 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-05-17 22:36:43.554 Initialised AES-256 server->client encryption
. 2005-05-17 22:36:43.554 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-05-17 22:36:43.664 Using username "uuuuu".
! 2005-05-17 22:36:43.745 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
! 2005-05-17 22:36:43.745 ~ Nel mezzo del cammin di nostra vita ~
! 2005-05-17 22:36:43.745 ~ mi ritrovai per una selva oscura, ~
! 2005-05-17 22:36:43.745 ~ che diritta via era smarrita. ~
. 2005-05-17 22:36:43.815 Keyboard-interactive authentication refused
. 2005-05-17 22:36:43.815 Session password prompt (uuuuu@xxx.xxxx.xx's password: )
. 2005-05-17 22:36:43.815 Using stored password.
. 2005-05-17 22:36:43.815 Sent password
! 2005-05-17 22:36:43.895 Access denied
. 2005-05-17 22:36:43.895 Access denied
. 2005-05-17 22:36:43.895 Session password prompt (uuuuu@xxx.xxxx.xx's password: )
. 2005-05-17 22:36:43.895 Asking user for password.
. 2005-05-17 22:36:50.534 Sent password
! 2005-05-17 22:36:50.614 Access denied
. 2005-05-17 22:36:50.614 Access denied
. 2005-05-17 22:36:50.614 Session password prompt (uuuuu@xxx.xxxx.xx's password: )
. 2005-05-17 22:36:50.614 Asking user for password.
. 2005-05-17 22:36:55.161 Sent password
! 2005-05-17 22:36:55.241 Access denied
. 2005-05-17 22:36:55.241 Access denied
. 2005-05-17 22:36:55.241 Session password prompt (uuuuu@xxx.xxxx.xx's password: )
. 2005-05-17 22:36:55.241 Asking user for password.
. 2005-05-17 22:36:58.295 Sent password
! 2005-05-17 22:36:58.386 Access denied
. 2005-05-17 22:36:58.386 Access denied
. 2005-05-17 22:36:58.386 Session password prompt (uuuuu@xxx.xxxx.xx's password: )
. 2005-05-17 22:36:58.386 Asking user for password.
. 2005-05-17 22:37:02.351 Sent password
! 2005-05-17 22:37:02.421 Access denied
. 2005-05-17 22:37:02.421 Access denied
. 2005-05-17 22:37:02.421 Session password prompt (uuuu@xxx.xxxx.xx's password: )
. 2005-05-17 22:37:02.421 Asking user for password.
. 2005-05-17 22:37:06.017 Sent password
. 2005-05-17 22:37:06.097 Received disconnect message (SSH_DISCONNECT_PROTOCOL_ERROR)
. 2005-05-17 22:37:06.097 Disconnection message text: Too many authentication failures for uuuuu
. 2005-05-17 22:37:06.097 Server sent disconnect message
. 2005-05-17 22:37:06.097 type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
. 2005-05-17 22:37:06.097 "Too many authentication failures for uuuuu"
* 2005-05-17 22:37:06.107 (ESshFatal) Authentication failed.
* 2005-05-17 22:37:06.107 Authentication log (see session log for details):
* 2005-05-17 22:37:06.107 Using username "uuuuu".
* 2005-05-17 22:37:06.107 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
* 2005-05-17 22:37:06.107 ~ Nel mezzo del cammin di nostra vita ~
* 2005-05-17 22:37:06.107 ~ mi ritrovai per una selva oscura, ~
* 2005-05-17 22:37:06.107 ~ che diritta via era smarrita. ~
* 2005-05-17 22:37:06.107 Access denied
* 2005-05-17 22:37:06.107 Server sent disconnect message
* 2005-05-17 22:37:06.107 type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
* 2005-05-17 22:37:06.107 "Too many authentication failures for uuuuu"
You should better check your server's log. Or ask server administrator. SSH client for security reasons cannot know cause of you being denied. But generally it is wrong username or password.
New user
I have a similar problem... When I log in with Putty it goes fine, but WinSCP won't authenticate me. I worked fine in the beginning, but yesterday WinSCP came up with a message that I didn't read before I answered yes (yes, I know, don't tell me!!), and since then I can't be authenticated by WinCSP.
Any advices?
Either post a log file or ask your server administrator to check server's log.
