Location profile
joeedmon
Location profile
When using Location Profiles to jump to a remote directory, if the local directory no longer exists the action errors out. It would be nice if instead a warning popped up and then continued to display the remote directory. It would also be nice if the Location Profiles were editable without having to go into the ini file.
Finally, it would also be nice if when a profile group is expanded, it remained expanded the next time you opened up Location Profiles.
Other than that, I love the program.
Re: Location profile
I'll consider that.
OK, no problem.
Maybe :-)
