Topic "external editor/multiple windows doesn't work 3.7.5"
beta51_tester
I am using PSPad. This only works when the option is disabled and the Warning prompt appears and you select 'No':
"Editor (application) launched to open file ... closed too early... To support this ... must adapt 'External editor opens ...' "
I then check, [x] Never ask me again... click 'No' and it works predictably. Then I close and restart WinSCP (with [x] multiple files in one window (process) option selected) and it doesn't work. PSPad: error saving.... Sad
Does 3.7.4 work for you? Note that I do not mean if it did, I mean if it works now, if you downgrade.
stanis
I've had the same problem using multilanguage version 3.7.5, and Notepad++.
I've tried to downgrade to 3.7.4 but the problem still occurs.
When I open a new file, WinSCP creates a new directory in %temp%. When I try to open another file, the directory is created but it's immediately deleted, so the editor can't find the file.
I close the editor(not only the file) before loading another file, this is the best way for me to work on multiple files...
Thx if you find a solution Wink
Stanis
So you open the first file, then you close whole editor and then WinSCP is not able to open second file?
Do you have enabled support for editors that open multiple files in one window?
I open the first file, then I close the whole editor and WinSCP IS able to open another file correctly. This is the way I work with it. But if I try to open a second file without closing the whole editor, it opens in a different (new) temp dir, but this temp dir is immediately deleted...
Enabling multiple file support in preferences doesn't seem to work. If disabled, the program asks me if I want to enable it.
I have tried that with Notepad++ 3.0 and it worked. BTW, what version of notepad are you using?
It should be enabled.
stanis
I'm using Notepad++ 3.0
Here's what I did :
- launch Winscp (I reinstalled v3.7.5 build 294)
- connect to the distant server
- double click on the file index.php, which is associated with notepad++
- notepad++ opens, with the index.php ready to edit (I can edit, save and it works)
- double click on index2.php, notepad++ (already opened with index.php) just opens a new tab for index2.php
- then, I can't edit index2.php because it has been deleted. Please check this link to screenshots and messages, the first image is the error message from Notepad, and the other ones are my complete settings. Can you see something wrong ?...
http://infowebp.com/winscp/
OK, I see the problem finally Smile
You open the file, you do not edit it. WinSCP does not support MDI editors for opening files (via association), because it cannot know if the editor is MDI. You need to configure notepad++ as external editor, set that it is MDI editor and use edit function.
However there is definitelly a bug that confused me (and maybe you too). Even if you use open command, WinSCP incorrectly offers you to enable support for MDI editors, even when it has no impact on open function.
stanis
All right ! I understand, and it finally works, if I choose "edit" instead of "open".
Thank you very much Very Happy
ivan g.
thanks guys, this was my problem also Smile
Leon
I have the same problem, and spent almost one month to find the solution. Someone should put this on the FAQ. Thank you so much for who ever posted the solution.
