Topic "SUDO VIA WINSCP"
rinishriju
How to do sudo in WIN SCP??
Iam trying to copy a file from one machine to another .
When I login to that machine using ssh I use to do sudo
But how to do that in WIN SCP?
Somebody please help me out.
Thanks in advance
Rinish
rinishriju
Hi prikryl,
Hope you understand my question.
I'll describe it again
Iam trying to copy a file from a Windows machine to a Linux Box at /opt/xxxx.
Usually I login to that machine using some ssh utility and do "sudo mkdir /opt/xxx" because iam a local user with sudo permision.
Now though Iam not directly loged into that machine Iam using WinSCP to copy my files to the linux box at the same location, but for that I have to do sudo and I dont find any option for that in WinSCP.
I would like to know if there is any option for doing sudo stuff in WinSCP ???
Rinish
You may be able to execute the command from console as long as you do not need to enter a password. Also read this FAQ.
rinishriju
Thanks for replying Smile
But for Sudo, I will definetly have to enter my password Sad
Is there any way to avoid this?
Very Happy
Rinish.
SUDO typically needs terminal emulation for entering the password. WinSCP cannot techically provide this. So you have the only option, configure sudo not to ask for password.
Thanks prikryl,
Thanks for the valuable imformation.
Any way I dont think sudo without password will work Wink
Rinish.
Sudo allows that.
rinishriju
Can you please tell me what is the configuration file that I should edit??
or some link will also help
Sudoers manual.
kpk
What I do is another kind of work-around, to avoid sudo-without-password:
Make a directory e.g. /tmp/c with full write permissions (chmod 777).
Then you can copy contents from Windows to this folder without sudo.
Then login via ssh/ openssh/ putty and move the contents to the required directory using sudo mv ... command.
KPK
Anonymous wrote:
Thanks prikryl,
Rinish.
Visitor
Thank you, kpk
