Topic "Does WinSCP run under Citrix or windows terminal server?"
Rabobank
hey all,
I was wondering is it possible to install and run WinSCP under citrix or windows terminal server?
I haven't tried that, but I believe that it should work.
micklweiss
There is no reason for it not to work.
-Mick
- Mick
JuergenF
Yes it works
wconwell*@...
Just a quick question...
Is there any way to store the key in a user's profile (which in on a network drive) after the first time they use WINSCP, or is the key always locally created.
Thanks for any help you can give me.
The key is create in HKEY_CURRENT_USER. I guess it depends on where the key is stored to by the system.
